Roman217
- Apr 13, 2018
- 366
- 342
- Location
- Metro Detroit, MI
- 2015
- 5.7
My lower ball joints are starting to loosen up and I would like to replace them sooner rather than later.
I can get the full OEM LCAs for 600 ish, but I'd rather not do the LCAs if I don't have to. I still need to check how the bushings are doing, if the bushings are bad, I'll probably the full LCAs. FCA also does not sell the lower ball joints separately so the only option is full LCAs if I went the OEM route.
Having said that, does any one have any recommendations for lower ball joints or full LCAs? All the ones I have looked up seem to have their own issues of not lasting very long to being over-sized, etc. I want to get a quality item that I won't have to touch again for a long time.
As a note, I have a 2015 Laramie 5.7 4x4 with 97k miles and I am on stock suspension (spring) with stock ride height.
With that, I am thinking I might as well do the upper control arms, tie rods, and sway bar links while I am in there. Thoughts?
Thanks in advance!
Thanks in advance!
