Leaf spring removal hints
USAFoffroad1999
Nor-Cal
5.9 V-8
I screwed up and posted this in the 3rd gen section so im reposting in the correct area.
So my Atlas Suspension leaf springs came in the other day and im thinking about throwing them in this weekend but after looking at the drivers side front leaf spring bolt , it looks dam near impossible to pull with out dropping/moving the tank . Does anyone have any helpful tips/hint to aid me in this process?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
you will have to drop the tank to remove the complete leaf spring. I encountered the same issue when I flipped my hanger to lower my ram.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
I removed the tank when I replaced my suspension, however there may be enough room if your tools are thin enough for you to just loosen the tank and shift it to one side.
U
USAFoffroad1999
Nor-Cal
5.9 V-8
Thanks , im hoping to not have to move my tank at all !
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Y'know...it's been a long time since I dropped my drivers spring pack out, but I'm about 100% sure we didn't remove the tank. My helper and I "dropped" it enough to shove it over and get a wrench or appropriate tool on the fastener. It was a tight fit.
I can't remember how much, but I know we didn't take any tank clamps completely off.
