Leaking rear brake line 01 2500 4x4
crazzywolfie
under the truck
just tape the end of the new line/fitting and feed it through the frame behind the gas tank. that is how i have usually done it. connect the front line first and generally by the time you are ready to hook up the rear line the line is usually bled resulting with little to no time spent bleeding air out.
