LED Switchbacks
DukeCity
Rio Rancho NM
Magnum 5.9
I'm thinking you would need resistors or you would get the hyper flash
4x4Hemi
Edmonton, Alberta
Get the ones from JJ at retroshop, they come with resistors and everything
05singlecabHEMI
Lilburn,GA
Yep, get them from JJ/ retroshop. Comes with everything you need! And you can have him paint them.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
resistors are a must....
Thats a really cheap price on switchbacks. Anyone have any idea how bright they are? I've had some like that before, just nowhere near as bright as what I offer now. :cheers:
MikeP
Brooksville FL
JJ are resisters needed for front and back? I have my rears in with resistors but if you run all four do you need four resistors?
Sent from my SIII using Tapatalk 2
Muddytazz
Salem, Or
2013 Ram 2500HD 4x4
Hemi baby
Mike, to my knowledge yes you would need 4 resistors
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
resistors are needed on any bulb that is a dual function (park / turn)
MikeP
Brooksville FL
Damn I was hoping the ones I installled in the tail would cover the fronts lol. Sorry OP for the thread Jack, thought this info might be helpful LoL
Needaram
SE WI
Cant you just get different flashers to fix the resistance issue?
Muddytazz
Salem, Or
2013 Ram 2500HD 4x4
Hemi baby
I don't remember the exact reason why but that doesn't work. It needs an inline resistor to slow down the flashing.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
JJ, you need a photo write up so everyone can see how too, and why :D
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
someday.........
logikfive
5.9L 24V Cummins
Resistors are required? That's funny.. Because I didn't install them and mine flash fine. All I installed was an EP27 electronic flasher, which is designed for LED bulbs. They hyperflashed with the OEM flasher, but once I installed the EP27 they flashed normal, and still do.
You can pick up that flasher at any autoparts store, generally an in-stock item for around $10-15.
Keep in mind, if you do go with the DDM switchbacks (Autolumination.com also sells the same style) that do not disable the white circuit (parking) when the amber (turn signal) is flashing. This makes them flash Amber, white, amber, white, amber, white, etc.
Other sources, such as vleds.com sells the style that completely disables the white circuit when the amber is flashing. This makes them flash Amber, light off, amber, light off, amber, light off, etc.
Here are some videos if you still cannot understand the difference.
DDM and Autolumination style: Switchback 3157's on a Dodge SRT-4 - YouTube
Vleds.com style (The ones I had in my Durango, and now have in my Cummins)
Daytime, but with a sequential flasher unit (The reason I needed the style that completely shut off the white circuit while they flashed)
The switchbacks I ran in my Durango and now I run in my Cummins were purchased a year ago from a seller on eBay. Each bulb has a total of 120 SMT LED's. 40 are white, and 80 are amber. The seller's name on eBay is str_led_lighting. He ships from the US, and is very quick. I've purchased 6 pairs of them from him with not a SINGLE issue.
Here is a link: 2 Pcs 3157 120 SMD LED Switch Back Dual Colors 80pcs Amber 40pcs White LED | eBay
MikeP
Brooksville FL
Ok so after a little research you can not use a EP27. Our trucks do not have a electronic flasher unit. Its handled but the TIPM. BUT I wonder how the cab and chassis guys do it with all the leds some of the aftermarket beds have?
logikfive
5.9L 24V Cummins
This isn't the fourth gen forum.
Second gens use a flasher. Third and fourth, most likely controlled like you describe (through the computer).
