LED's N' Lightbars
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Finally got my light bar installed and wired...
always solder your connections, use some good heat shrink, you don't want any unexpected electrical fires...
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
I removed the splice in the wire where the light and harness connect and soldered them together because of the routing location it could have shorted out. I added a weather proof connector under the hood for easy removal...
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
I also removed the notorious butt splices from my 12" on the front and installed another weather proof connector...
and the end result.
derekp
Buda, Tx
1990 5.9 Cummins
Looks good. Are those the brackets I showed you from jm kustoms?
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Those are the mounts that you told me about and they are pretty stout. I appreciate you letting me know about them... had em' in 2 days.
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Looks good! Where you get light bar?
I got the light bar off Amazon, it's not a Rigid... sigh. I'll see how the IP68 standard that they claim this light has holds up. If it retains moisture by the end of the year I'll put my refund to use and get a Rigid.
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Got my floor lighting installed and everything fades up and down with the dome and map lights...
*>Big thanks to (Rzrman328) for sending me the link for the lights and giving me the initiative to finally do the this mod.<*
derekp
Buda, Tx
1990 5.9 Cummins
You're welcome man. I like mine too, especially since they are steel. By the way, did you have as much fun as I did getting those brackets bolted in? Lol
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
I put the mounts and bar on at lunch time on Thursday... it was pretty simple for me as I used the screws that hold the weatherstripping on that were closest to the top of the windshield. I had a screw in the front holes at the factory location, I then lined up the mount and got it level, and hit it with a center punch in the middle and rear holes. Pulled back off, drilled and tapped it with a 1/4-20 and put SS button head screws in. The guy sad that his mounts would fit a 52", but when I was putting my light on it was a snug fit and put some tension on everything.
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Got a few night pics of the lights, like everyone says when they take pics like this there's no justice for how bright they actually are...
only the 12"...
only 52"...
12" and 52"
These lights are super bright and will work just fine for rolling around my land.
derekp
Buda, Tx
1990 5.9 Cummins
Looks good! How's the wind noise while driving?
robertlanajean
I would love the contact info for the guy that sells the mount. Need a nice bar to light up the night.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
SilverStreak88
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Got my dome and map lights installed this evening...
Nothing like being able to see in the dark, now to move back to the outside and do my new fog lights and fit em' with LED's, my cargo light and reverse. I'm sure those won't be the last either, these LED's have become an addiction and I love light's.
derekp
Buda, Tx
1990 5.9 Cummins
You have joined the dark side of the leds...muaha haha
Do I see a dash swap in your future? :naughty:
You know you want your interior to look like this...
JustinRam1500
