Left rear speaker has power but no sound
USMC03
Heber springs
Hello I’m new to this forum stuff but am having an issue with my left rear speaker in my 13 ram. It has the 8.4 inch uconnect and everything works fine but my rear left speaker. I’ve test it and it has power and no broke wires from what I can see but still no sound. I’ve flipped that specific speaker to another door and it works fine. Can anyone lead me in the right direction in trying to find the solution?
osprey92
Try connecting the other speaker to the left rear. If it works, it may have been a loose connection. Not working, do you have any connectors or adaptors between the factory harness and speaker? If yes, you could have a broken pin or wire that shifts and supplies power when the connection is moved around. Replace the connector/adaptor. If that fails, look for rubbed or bent wire connections in the door harness.
