Level kit with tires (33"/35")
Saetun
Saetun
06 1500 Quad Cab Big Horn
4.7L
No luck on a 3"x2" level kit for a 2wd from forum vendors. Anyone know of a vendor I might try other than the Ebay vendor which I referenced on a previous thread? Thx.
SMITHY
KANSAS CITY
2011 Dodge Ram Quad 4x4
4.7 Magnum
A 3" level up front will give you bad cv angles and likely shutter in 4wd. Stick with a 2.5" up front.
As far as 35s, a ton of 02-05 guys are going to tell you it will work. That's mostly because they don't understand that 06+ switched to a strut suspension up front, whereas they have a torsion bar suspension. Totally different.
You can run 35s in a straight line no problem, but they will rub on every speed bump, every full lock turn, and maybe even in and out of your driveway.
I ran 35s with a level and hated it. I added a bodylift and it was perfect. Sometimes I wish I stayed with the bodylift and level.
So do you think if I go with the Bilstein 5100 adjustable up to 2.75 will cause the shutter/vibration to? I am also going to add .75 spacer in the rear and it should be .1 inch off perfectly level.
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
you might not find a 3" front level with included rear block, but you can buy both separate from reputable dealers. thats what i did. btw, you can look at my sig, 3" front level 285/75R/17s, but then again, i am on a 2500 platform.
