leveling parts with zone & bills
Hemi Hunter
Utah
Finally got my zone upper arms and bilstein adjustables. I'm asking for input in regard to either using these parts on the 2.1 setting and be done, or is it better to perhaps set them at max and add a 3/4 rear spacer to get the leveled look? I just want others thoughts on the best way to utilize these parts. Also am adding the airlift bags for trailer duty. I'd like to hear from other members with there bils set at max regarding vibration or any shaking n such if it is much of an issue. Any input would be appreciated.
scubasteege
I have mine set at 2.1 and have not felt any vibration in 4x4. I still have about 3/4 inch of rake but it looks level to me.
lokal907ryder
wasilla, AK
i have mine set @2.1 with the ZONE UCA's and it sits pretty good. im running 33x12.50 on stock rims. i want to add 1.5" BL and 35's
Hemi Hunter
Hemi Hunter
Utah
Yeah I have noticed most seem to do the 2.1 setting. I'll most likely go that route. Adding a 1.5 body lift someday might be a good look later on. Damn I like that blue color a lot lokal.
scottyram
Ontario Canada
Exact setup I would be running if my 5100s would finally come in, I've been waiting on them for 5 weeks now :(
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
I felt very slight vibration at 2.1, but I'm **** about these things. No one else felt it though.
But 1.4 and 2.1 are good settings in my honest opinion. Plus the lower you set them, the better your truck rides.
I have mine set to 1.4 on my 6" lift and there was a noticeable difference in ride going down from 2.1
2.75 felt 'rough' for my liking and from 5-10 miles there was a vibration feeling.
But remember Bilsteins/leveling kits react differently on all trucks.
TX-RAM-MAN
San Antonio
5.7 HEMI 4X4 Sport
Has anyone installed front and rear bilsteins? I've been searching but can only find info on people putting front only with a UCA. I was wondering if set them to 2.1 in the front. Then added the rear bilsteins. Would the rear still stay at factory height or make more rake?
fastNugly
Toronto, ON
Rear Bilsteins do not lift the truck, however, they do allow for an additional of 1" lift via coil spacer.
But the rears do not adjust like the fronts
TX-RAM-MAN
San Antonio
5.7 HEMI 4X4 Sport
So in theory I would be able to set the front at 2.8 and add a 1" spacer, and then add the rear bilsteins and it would still be level? Just checking. I really only want the front to be on the 2.1 setting, but also want to change out the rear. So as long as it will still sit good I'm gonna order them today.
fastNugly
Toronto, ON
Typically 2.75 will level or nearly level many of our rams if have the avg rake or 2.75-3"
The 1" rear coil spacer goes on the rear.
Many will add, if they want to add some rake back from towing reasons, loading weight in their bed or simply just wanting rake but overall, wanted to get their ram higher off the ground.
Based on your comments, do the 2.1 and rear bilsteins and don't add a rear coil spacer. You will eliminate a lot of your present rake, but still have some.
I personally like the 2.1 setting myself.
Too level of a ram appears nose high when parked on uneven ground.
TX-RAM-MAN
San Antonio
5.7 HEMI 4X4 Sport
Awesome! Thanks for the help. Gonna order front and rear today! Also getting the UCA from your site!
DisturbedGator
I did a similar setup to this on my 11. I went with a .75 spacer in the rear with the bils set at 2.8. Than added the 1.25 BL on top and truck looked awesome (actually still my sig pic). However I did have a pretty good vibration in 4wd. On this 14 I plan on 2.1 and just a 1.25 BL. Unless my new business takes off than Ill spring for a 4" lift and call it a day.
fastNugly
Toronto, ON
You had some great DIY threads.
As for your new truck the RCX 1.25 doesn't work. But you have the 1.5 Zone option.
