Lift help
Irishfan
2014 sport
I'm going to stick w the stock size tires and wheels on my 2014 sport. New tires soon but same size. With that in mind, I only really want to lift it 2-3 inches. I'm more hoping to get that little height but mainly to make my 75 mile daily drive a smoother one. I know very little about this, have been trying to research and research locally where to do it. Price is not that much of an issue. But I don't know really what is a lot to spend on something like this. Few grand?
H3MI UP
Southeast ga
You could do a leveling kit to get you 2" but not sure your ride will change. If anything it will stay the same or worst.
Solid State
2011 Bighorn
Do you have a 2x4 or 4x4? If its 4wd, look at getting bilstein adj shocks for front, and maybe run a .75-1" spacer in the rear. Zone sells a 3.5 combo lift kit, might be worth looking into. From there, 4" full suspension. I know nothing about the 2wd, so I'll let someone else cover that one.
Scgirardi
Put bilsteins on and set at 2.1 inches stock tires will look fine
I
Irishfan
2014 sport
Thanks for the replies. It is a 4x4
In regard to bilsteins. They seem to be a very popular choice around here. Is there something that makes the ride better than these? Only asking as I imagine there must be
Solid State
2011 Bighorn
Yes, tons of shock options. Money being your only factor. Fox, king, icon. Most guys just go with bilsteins as they are cheaper and are a btter ride than factory.
mpittman
Indiana
2015 Big Horn Crew Cab
Yes Bilsteins are better ride than stock... they get the most support around here. $200 or so for the set. You could use them to raise your truck 2" - 3" as they are adjustable up to 2.8". If you want to keep a little bit of rake, you can raise the rear with a 1" spacer.
I have a full 4" BDS suspension lift on mine, and the ride is as good or better than stock.
Scgirardi
its personal preference in regards to being "better" then stock. Bils are a firmer ride. Not by a lot but they are. So your ride won't feel like a 80's Cadillac floating over everything.
Scgirardi
I'd also not set your bils to 2.8. You having a 2014 your just asking for ball joint failure. Anymore then 2.1 get a set of uniball uca's. 2013+ models changed there uca's for the worse.
