Lift Q's
Manutea
Diamond Bar, CA
Just got out of a shop nearby, and they are charging me $2000 for a CST 7" Kit w/ schocks; and $4000 installed with 35s Nitto Trail Grapplers. Does that sound reasonable ?
At first I wanted a 4" Lift with 35s, but he said it wouldnt fit.
Its either 4" with 33s or 6-7" with 35s. Is that true?
Would 33s fit on the RCX 3" Lift?
so many questions.
What would you suggest? Any opinions appreciated
All I want is keep the gap between the tire and the fender as small as possible.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
You can fit 35s with a 4" lift for sure as long as you have the right offset wheel to keep it from running. Usually a 6-7" lift will take 37s to look right
Manutea
Manutea
Diamond Bar, CA
Im planing on keeping my Rims for now. Should I consider wheel spacers then ?
ZakkBaker
FTW, TX
5.7L HEMI
I have the 3" RC lift with 33's, mines 2wd also. Fit fine.
You could maybe fit 35" on the 3" , with a little rubbing though.
And like blackout said, 6-7 would fit 37"s.
inktoxicated
nj
i have 6' lift on 35s with -24 offset (wheels stick out 2-3 inchs) the setup would not work with 4 inch lift it would definatly rub. i paid 1200 for kit about 1000 for install and alignment wheel/tires were 2500
blk05hemi
Bovina, TX
Cummins 6.7
Yep! i installed my 6" RC on mine with 33s on stock backspaced rims and it was undrivable without spacers.
ramin44s
4.7 v8
I run the 7" CST and rub on 35s Bc of wheels being 10" wide and negative offset go with a small wheel spacer up front on stock wheels and you should fit 35s on the 4"
Reticle918
