Lifted 2wds
rennaissanceman
Tampa, FL
I could use that notch, I'm not even lifted and my best bet of making a 2 lane U-turn involves either drifting or running over the curb
Oefootball_70
Oefootball_70
OLATHE
thats weird guys i still feel like i can turn fine havent had any issues maybe its bc im CST
Might be, who knows. I know mines decreased. He said he did have pictures that he just grinded a little bit at a time.
Ramunit
Beautiful 10 year old lifted atlantic blue~~~~
Mcknigha
Dahlgren, VA
New guy, Can I put 18 inch rims with 35" tires under a 03' ram 2x4 with a 3" lift without it rubbing?
ramin44s
4.7 v8
probably not depends on the wheels offsett and backspacing, probably would be better with 6'' and 35s. what type of lift are you talking about suspension, body ?
Mcknigha
Dahlgren, VA
Suspension lift with a 19mm offset on the wheels. I'm trying to do a 3" in the front and 1.5" in the back.
ramin44s
4.7 v8
its a spindle lift then im assuming, you can run that spindle and get a 2.5 or 2'' spacer for cheap (150) and have 5 close to 6'' lift and fit 35s easy 3'' alone will be cutting it close,
ramin44s
4.7 v8
also check the lift manufactures recommended offset for wheels some spindles lifts require a more negative offsett to keep the wheels and spindles hitting
ramin44s
4.7 v8
you can run those and get a 3'' spindle and be alright
Mcknigha
Dahlgren, VA
This would lift my truck 6" right? I'm really trying to do my lift in stages cuz of $$. I was thinking do the RC lift with 34's, then do the spindle's with 35's when the 34's wear out.
ramin44s
4.7 v8
You can probably get away with that with no trimming
Oefootball_70
Oefootball_70
OLATHE
RC sells the 3 inch lift springs. But those dont work with their 6 inch kit. The 6 inch kit lifts you six inches but also drops the crossmember to retain stock measurements, stress, distance, yada yada, with the lift.
TexasRammer
College Station, TX
Oh true, ive never really looked into the 6 inch kits
Oefootball_70
Oefootball_70
OLATHE
Best part about RC and Fabtecs lifts are that you can stack a coil spacer up to 3 inches and its just like a factory suspension with a spacer. So you can run the 9 inch suspension lift no problem.
Arturo Rojas
