Texasez
I have an outdoorsman and ordered the bilstein 5100s for all four corners. I measured and I'm at 36.75 in the front and 39 at the rear. This is measured to the fender flares. I thought most had about 3" of rake so Im not sure why mines less. I was going to set the front at the 2.75 and then add an inch at the back since the rear 5100s can be set at an inch. Does that sound ok. I know a lot are doing 1.75 in the rear but I didn't know about doing that with the bilsteins. I didn't know if that would be over extending them or causing extra strain on other components. I like a little rake but I want it to work with the 5100s and don't want to change stuff so much I start causing extra strain on stuff. I saw TGC has the steel coil spacers for the rear. Does anyone know if Moes carries them. I only saw lift kits on their site.
