I TRIED IT 4 TIMES AND IT KEEPS COMMING UP WITH "oops" Maybe it's not up and working.Find your Vehicle Identification Number, VIN, and fill in the blank on this
form, using only CAPS for the letters. It will give you the total build sheet
for every option you have or don't have...
https://fcagroup.my.site.com/RAM/s/equipment-listing
This is what I have seen. I'm interested in where you gathered this information and is it for the Heavy Duty 2500 and 3500's?I THINK they used the marketing term "anti spin" for the torsen all gear AAM TracRite differentials. At least they did for mine. And used "limited slip" for the clutch differentials.
It's hard to keep track of what the MBA's are up to.
I also read FCA got rid of AAM for a cost reduction / profit improvement. a-holes
American Axle & Manufacturing (AAM) has announced that it has secured production for the next-generation axle and driveshaft program for Ram’s next-generation of Heavy Duty pickups and Chassis Cab trucks. The Detroit-based manufacturer stated in a press release on Friday. It will continue to be a Ram strategic driveline supplier through 2030.
I have a 2014 1500 Limited with the 'anti-spin'.
Either they didn't install it or it's pretty much useless because on slippery surfaces, only one tire will spin, no matter what.
How many miles on the truck? When was the last time the rear axle fluid was changed?I have a 2014 1500 Limited with the 'anti-spin'.
95k on the original fluid.How many miles on the truck? When was the last time the rear axle fluid was changed?
The 1500 versions were clutch based and thus simply wear out. I've seen big differences between a brand new fresh unit as compared to one with 50,000 miles on it. If there were 100k+ miles on the original unit it probably is useless!
