LMC Finally !
Dodgefreek89
Hey guys im not sure if you all already know or not but i just found out that lmc is finally gettin a magazine for 1st gens and ram chargers. Website says not till spring of 14' though. But i Just wanted to give everyone a heads up
I tried to order one now but it wouldnt let me maybe only certain styles can pre order.
Catalog for Chevy, GMC, Ford and Dodge Truck Parts and Accessories - LMCTruck.com
DodgeAddict
Chambersburg PA
5.9 Magnum
Don't hold your breath on the catalog They've been promising this for at least 3-4 years now with "Will be available spring of 20??"
I go to their store & get tilt column parts from them & they laugh when I ask about 72-93 truck catalog Their store is roughly 20 miles from me
The only reason why they have the tilt parts is because our Mopars have a GM tilt column
itsadodge
Slant 6
I know this is off typic but, dodge trucks use gm tilt column? Like would a gm column fit in a first gen dodge ram?
Thanks
-23
crazzywolfie
under the truck
from what i remember you are thinking of a 70's dodge truck that used a gm tilt steering column. on the 80's and newer trucks i am pretty sure used a dodge built column. are you good with electrical? if not i think changing columns would be impossible since trying to find a 81-87 steering column with tilt would be pretty hard. you could possibly use a newer steering column but it would require a lot of wiring but if you don't have delayed wipers it would be a good time to add them.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
The tilt column started in 78 I think and the Dodge columns for 78-8? are pretty rare so some people used GM columns to replace them.
itsadodge
Slant 6
I went ahead and "pre ordered" the catalog,
Thanks for the info guys
-23
crazzywolfie
under the truck
i have had 3 ford catalogs show up already but no dodge catalog and i don't own a ford
DodgeAddict
Chambersburg PA
5.9 Magnum
Thanks
-23
ALL Mopar tilt columns till 87 were GM columns
I rebuild the 68-87 Mopar tilts
As far as a column made for a GM fitting NO
RamV10
Western Central NV
V10
Thanks
-23
P/S Pumps were GM, Dodge used Q-Jets from GM also. Why build your own when you can use a proven part. GM had some of the best steering out there in those days IMO.
itsadodge
Slant 6
So gm built the column for dodge but it's not interchangeable, right?
