Local help
RCKable
Virginia
I apologize if I should have this somewhere else in the forums. I am looking for someone near Lynchburg Va or within an hour away. I just need to change mileage/engine hours on a 7” cluster when it comes in. I was hoping someone would help me out that has the bypass cable, alfaobd, and OBD2 adapter. I have a 2018 1500 Tradesman.
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
I'm in Lynchburg, have alpha obd, & obd adapter but not a bypass cable. Happy to help but don't have everything you need. If you source a cable hit me up
RCKable
RCKable
Virginia
Thank you. I’ll definitely message you if I find one. Or just buy it.
Bigskyroadglide
This use to be the source. Not certain if it is now or not. You will need to check
