Lockers which one
Troublewalksin97
Kennewick wa
318 magnum
I have a 97 1500 Ram 4x4 with a 5 speed manual can anyone give insight about finding the right locker for my rear differential which ones r good where to find one at a reasonable priced setup would also be a big help I’m sure one of you guys has some good advice on this topic,
I’d appreciate it
bm02tj
B C Canada
ARB or Eaton E locker selectable is best
If you mean LSD the Trutrac
T
Troublewalksin97
Kennewick wa
318 magnum
The other question I had was if there is a difference in the manual trans and the automatic gears in the rear ends I assume there would be Reason I ask is because I have two Ram pickup one auto and one manual but the ratio and all the other info it’s been faded so badly you can’t read it under the hood on the manual Ram I need to know what I’m looking for as far as numbers when I go to get one
bm02tj
B C Canada
Jack the truck up mark the tires and drive shaft then count number of rotations of drive shaft to one rotation of the tires
just over 3.5 turns will be 3.55
also rear end should have a tag on one of the cover bolts
