Looking at buying a 3500 opinions/experiences please!
Rkane171
Canada
I’m looking to buy a 2019 ram 3500 6.7 Cummins 100k on it from a dealer, my main questions are.
Reliability?
How much is fair price?
Which trans is better in it?
common issues?
And just over all general things I should look at before I pull the trigger on it! Thanks in advance!!!!!
Gary Hogan
Weatherford, TX
See if the recall for the cp4 high pressure pump has been done. I have 2019 3500 with 46k miles and have had issues with the dpf and frequently regenerating. I finally deleted it, tired of the dealer and Chrysler.
Billet Bee
South Dakota
Cummins 6.7 HOHD
Reliability?
common issues?
Do you tow any heavy trailers?
How heavy of a trailer do you tow?
How often do you tow the trailer?
Does the truck your looking at have the rfe or aisin trans?
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
The 2019 and 2020 models had a lot of recalls. Especially the fuel pump on the cummins. If that wasnt done, the failure of that pump could cost upwards of $10k. I would really make sure all those were done.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Reliability?
common issues?
I'm assuming you are getting a one-ton for pulling better than 17K pounds. The Cummins comes in two configurations, standard output with the 68RFE transmission and the high output with the Aisin transmission. I guess I would take the vehicle with the engine/transmission combo it has as long as it meets your needs.
If I were buying this, the first thing I would want to see are the service records and as mentioned, if all recalls were performed.
Used vehicle pricing is falling from what I'm reading and used vehicle prices are typically regional. Figuring out its value isn't going to be easy. Most likely your dealer paid more for the truck than its current market value. I'm assuming Canada's used car market parallels ours.
John Jensen
San Diego County
Ecodiesel
Interesting that you say "a lot of recalls".
My 2020 HO had only two recalls.
One to replace the HPFP which was/is being done on all Rams and Jeeps with a CP4 pump. And, a dealer cannot resale one until the pump has been replaced.
The second was for the tailgate latch which consisted of a visual inspection to see if the tailgate was aligned properly.
To Rkane171, BossHogg gave you good advice.
To add, the 6.7 Cummins is probably the most reliable diesel available. The Aisin Trenny is the strongest available. The 68 tranny is excellent but needs programming if a tune is employed.
Easy way to spot the difference is the transmission dipstick tube. The 68RFE is on the passenger side, the Asian is on the driver side
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
My 2022 2500 has had 5 recalls so far. Obviously some of these are VIN dependant. My last Gen4 truck had 14 in 8 years.
totalsistem
