Looking for 2018 Power Wagon
cubmedic
Danville, Va
Hemi 5.7 e-torque
I am looking to trade my 2016 1500 crew cab Big Horn in on a Power Wagon. I have found one I like but it does not have the 8.4 radio in it. How much trouble would it be to go from a 5 inch radio to a 8.4?
56PW17
Pa
Is it a tradesmen model?
Low_Sky
6.4L
You’re going to get more views on this question out in the 4th gen section. It isn’t a Power Wagon specific issue.
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
What are you looking for and how far are you willing to travel? I’m the sales manager of the largest dealership in the Baltimore area, I may be able to find exactly what you’re looking for.
cubmedic
cubmedic
Danville, Va
Hemi 5.7 e-torque
Sent you a PM
Nick@GotExhaust
Supporting Vendor
SC
Check out the vendor section for M2Mods. I believe they make a harness to do this conversion. Very knowledgeable guys and very helpful as well. If they dont know the answer I am sure they can get you heading in the right direction
@Mpgrimm2
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
If you're not close enough for IrSmart to set you up, it's possible.
How easy it is depends on what radio/options are in it currently.
Q: Does 18 power wagon at least have a 5.0 Ra2 with the phone/VR buttons on the wheel (& mics in the headliner)?
Q: It's a 2500 correct (4 speed factory fan/blower)?
If the answer to the above questions is yes, then it can be done. You would need...
18 ram UAS or UAQ (Nav) radio $900-$1300 new
13-18 Ram 8.4 radio/MTC HVAC bezel $60-$130
18 Ram 2500 HVAC module. appx $130
7 speed blower motor resistor. appx $40
From us you'd need...
4 speed 8.4 conversion harness $145
4 speed 8.4 fan motor harness $55
Be aware, your truck wouldn't be able to use the factory uConnect/guardian services since it didn't come from the factory an 8.4 radio and the dealer likely won't warranty anything associated with the switch.
It would likely be cheaper to just get a pw with the radio you want vs doing the upgrade. Since the 18 radios have Android Auto /CarPlay you don't really need the UAQ with built in Nav unless you want a backup. If you want, send me a message with your contact info and I can give you call to discuss any specific questions you have.
*2013-2017 8.4 Conv for 4 Speed Fan Trucks 7-6-17.pdf
* Note: our v3 fan harness doesn't require repinning any connectors *
How To: Install a 2018 4C (UAQ/UAS) Radio in 2013 - 2017 RAM.
2018 HVAC module PN: 68366553AA = 2500/3500 trucks w/8.4 radios (ATC)
ie factory 4 speed fan (w/Sgl speed A/C Compressor)
M² Mods.
