Lost high beams after enabling auto high beams
Azmp1
So I’ve enabled auto high beams (with AlfaOBD), after installing the new mirror and the function works fine, however high beams on demand (pulling the stalk towards you) no log her does anything.. so with gaining auto high beam function, I’ve lost ability to flash high beams on demand… any idea on how to fix this?
diymirage
Banned
I would guess there is a "flash to pass" setting that needs to be enabled
diymirage
Banned
Any idea where it would be?
Same place you found the "auto high beams"
You know, that general "change configuration" area of the BCM
I would do a search in there for "pass", "beams", or "brights"
Azmp1
Azmp1
I will look, thank you!
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
My 14 has auto high beams. You are in auto or not.
If you want to flash, you flip the turn signal stalk just like you normally would by pulling it towards you.
Azmp1
Azmp1
Can’t find anything… the only two lines I see is for enabling auto high beams… nothing else related.
Azmp1
Azmp1
That’s the problem. My 14 didn’t have the auto high beams, but as I’ve replaced the mirror, it now does and auto high beams do turn on, but I’ve lost the ability to flash on demand. Nothing happens anymore when I pull on the stalk, like you usually would.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Much more than changing the mirror is needed. Quite a few items to change / check with AlfaOBD for the Auto high beam.
Did you do / check the following?
ECU Qualification: Auto Headlights Present: YES
VehConfig 1: Auto High Beams: YES
VehConfig 3: Auto Headlamp Feature Present: YES
2014 CNC Config I/O & Feat: Auto High Beam Module Location: ECC AHBM
CBC Extern.Light Calibr.: Auto Headlamp On Threshold (0‐5 V): 3.314 V
CBC Extern.Light Calibr.:Auto Headlamp Off Threshold (0‐5 V): 2.549 V
Cust.Set.Menu 1:Auto High Beam CSM Present: Yes
Cust.Prog.Features:Auto High Beam: Enabled
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Compare the original configuration image you captured (hopefully) to the current configuration using a file comparison utility, looking for unintended changes.
noraa73
