Flryder
I started my 2012, 4.7, 4x4 Ram with 116,000 miles and put it in D. It showed 4th gear, not D and went from park to this gear very abruptly. When I gave it gas it was very weak feeling. I drove it about a mile and it kept acting in this manner, never showing any other gear but 4. The + and - would not change the gears. Putting it in reverse was also very abrupt. Going from P to R to N to D was very abrupt. I then scanned it and got 9 codes. Some were repeats. Here they are:
PO876
PO882
PO731
PO846
PO871
PO988
PO868
PO869
I then restarted it to check the fluid level which was on the lowest two holes and nice and pink. Then I ran the shifter through the gears and all acted normal. No more abrupt shifting. It would show D when it was in D and the + and - worked. Moving the truck forward and backward seemed normal. I looked up all the codes and they were all transmission codes relating mostly to fluid pressure.
Any ideas or suggestions?
Thanks,
PO876
PO882
PO731
PO846
PO871
PO988
PO868
PO869
Thanks,
