Mule19
Dorman 265-870 Transmission Pan... https://www.amazon.com/dp/B07FZ6F5ZK?ref=ppx_pop_mob_ap_shareLink to pan on Amazon?
No problemThank you!
Seems like a decent filter being that its a wix. Not sure if you could use synthetic fluid?
For those using the metal adaptor for the spin on filter, which side if either are people putting blue locktite on? I would think the filter side?
So what I need to buy is :
1) WIX 57055XP- knock the paint off the canister
2) Ebay, metal hex thread adapter
3) ATS thermo bypass valve up grade
4) OEM Mopar sump pump filter
5) pan gasket sealer of some sort (rtv or cork)
6) Redline C+ Synthetic transmission fluid, 7qts roughly
And I will have one hell of a 66RFE !
So I should wait till out of factory 5yr/60k warranty?
Wouldn’t this kit work to fix the accumulator issue just as well? Along with the upgraded accumulator plate from them.
I’m not a big fan of ATS transmissions. The diesel guys will tell you they make a trash transmission.
https://www.sonnax.com/parts/4688-accumulator-piston-kit
https://www.sonnax.com/parts/33-accumulator-cover-plate-kit
For sure, the info posted should be viewed only for the sake of showing the weaknesses of the rfe, I suggest anyone research different brands to find the best for them. There are a few options, I have no opinion which one is better. ATS has had some quality issues when these first came out according to many reports, some say those issues are over, i have no idea either way.
