Low beam out message
alex_5_7
I did a cluster swap and it's telling me my low beam is out... I have hid with a relay so there is nothing plugged in to my passenger side OEM connection. Anyone have any solutions?
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Did you swap with a cluster from the same model year as your truck? I seem to remember some model years being more sensitive to HID conversions on whether or not you get a message.
wangatang
AZ
Cummins 6.7
if you have a 13-14 you have 2 options:
-use a reputable canbus error eliminator and drive the ballasts from the oem wiring
-install a resistor on both sides so the truck sees a load and stops displaying the error (I did this on my 14)
if you have a 15, I think the only thing you can do is run resistors to simulate an accurate bulb load.
