Low beam projector issue
jcobbdawg
Bloomington, Indiana
2018 RAM 1500 Sport projector headlights: my low beam passenger side went out. Changed the bulb but it’s still out. Message says it’s out but my high beam, turn signal and DRL still works. Is it an easy fix to change out the low beam connector inside the housing?
Hodgetts
Ontario
Ecodiesel
Hey I have the same problem did you ever resolve it???
RamCares
n/a
n/a
Hi @Hodgetts. If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please be sure to follow up with us via private message. We would be happy to offer our support!
Kathryn
RamCares
Dr B
Hollister
I too would like to know. Just this week the dash message low beam error showed up for the passenger side. Changed the 9005 bulb but that did not fix the problem.
