Low range nannies are still on why?
Snowchief
Milwaukee, Wisconsin
Going to run sap( maple syrup) still alot of snow to get in tried holding button 5 seconds says both esc and traction control are off. Nope still cut power truck got stuck had to winch out . So tried low range which it displays that esc and traction are off. Nope stuck again winch out now says four wheel drive temporary not available Wow! Finally it engages but still all the nannies are kicking in causing yep truck loses power and stuck. I hate these new progressive trucks.Is there a way around this like fuse f26 ?
John Jensen
San Diego County
Ecodiesel
I experienced the same getting stuck in powdery soft desert sand.
Ordered the ABel bypass modified to connect to an Aux Switch. In my Eco the fuse is F26, in my 2020, HO it's F11
S
Snowchief
Yep it was F11. Truck is back sapping going through snow and mud like my old pre nanny trucks (which probably will go back to) Thanks again and some pics
RamDiver
Marlborough, Ontario, Canada
When you were attempting to defeat the ESC control, did you ever receive a notification on the EVIC?
I've found there are different levels when it comes to disabling the feature and I believe it's not truly disabled until you see the following notification;
danielmid
Southeast WI
2015 Sport 4x4
Yep, pull the abs fuse.
Then, order up the Abel bypass switch for it so you can do it on the fly inside the cab and not have to pop the hood every time you wanna disable the feature.
Do you have a link for the Abel mod? My google-fu is failing on it.
Dean2
Near Edmonton
Is there a difference in the Nanny features in the HD trucks by year. Mine is a 2021 Gas 2500 and in low range I do not find that the nanny features are active at all. Even in high range, I seem to be able to turn them off with the TCS button.
Even in real bad mud and low range I don't perceive the truck trying to limit wheel spin as it will throw big rooster tails. I have never worried about whether ABS braking was off or on so can't comment on that. Am I missing something?
S
Snowchief
Well last season it was just mud and truck worked fine.This snow was much deeper and you really need to keep speed up to get in and it was terrible. It was like it cut timing truck would just fall on its face and time to start winching. Low Range did the same.
S
Snowchief
Yes notification was displayed. I read somewhere that if wheel speed hits 40 mph esc and traction control comeback on. I have a video of how well it performs after pulling F11 just not sure how to post it.
Administrator
Post the video on a video sharing site like YouTube and then share the link.
John Jensen
San Diego County
Ecodiesel
Correct, "ESC. TCS and Torque Reduction features are turned off until the vehicle reaches a speed of 40 mph. At 40 mph the system returns to “Partial Off” mode. The “limited slip” feature is not turned off."
That's a locker bypass, I assumed they were discussing an ABS fuse bypass mod.
