Lower Ball Joint
Taylormade76
California
My ball joint needs replaced and I can't get the cup to fit behind the ball joint to press it out.
Do they make it to where the whole arm needs replaced?
HemiLonestar
Navy Badge Coast Guard
MD
Chisel off rivets and replace joint or just replace the whole arm.
aviatorblackout
NC
Are you using a ball joint pulling tool? All the big auto supply stores will rent them to you for free. It is definitely supposed to come out, they are pressed in and can be very hard to get out. With the right ball joint kit it will work, but you might need to heat it up with a torch to help it along.
10 Break
Dayton, OH
Supposedly, chiseling away at the peening around the ball joint will free it up to press out. After 2 days of working on one, I replaced the LCAs.
Octane
U S.A.
Airchisel those rivets off and it'll fall off.Bolt the new one in.
No members online now.
aimcgma
