Lower running boards ?
mamaluke
Pontiac , IL
Looking to put running boards on my 4x4 Laramie . Are there anything that sits a little lower than most . Wife has a bad hip and I need to make it easier for her . No power boards .
22hemi13
Tucson AZ
2014 2500 4x4
Maybe take a pair to a local welding shop and have them make up something.
cuminslvr
Pennsylvania
3.0 Diesel
Check out the Amp-research power steps. They come down quite a bit lower then stock boards and they retract with the opening and closing of any door. They also have a plug and play install that plugs into the OBD port so no wire splicing.
amp-research.com
grizzstang
Calgary, Alberta Canada
Nfabs hang pretty low. I put them on mine so my 71 year old mom and 91 year old grandmother could get in and out. My mom has a bad hip too and is waiting to have it replaced. They make several different styles. The Podium Nfab have the step loop filled in. They also come in stainless steel if you prefer that.
full
crazykid1994
If your truck is a crew cab the 2500 crew cab steps hang lower than the 1500 steps
crazykid1994
I was kind of leaning for something like the nfabs .
That’s what’s on my truck. I like them. Girlfriend likes them. Only problem I had was the powder coat chipped real easy. I got them sprayed with linex
