Lowered shocks
seamasterbond
Ohio
Hi I have a lowered 2014 2 inch and rides little rough is there a softer shock I can use that will make ride better? Not sure what’s on it now I bought it that way thanks
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Lots of lowered truck owners go with qa1s or bilstein. One is adjustable the other not so much.
6speed4.7
Winnipeg
Not sure if I’m reading this correctly…
If you’re only lowered 2” in the rear, you ride should be very close to stock
I’m with Nate, sounds like shock replacement time
Bigskyroadglide
Moderator
You have one lowered? Is it a hard ride?
My ram is lowered 3 inches in the front and 5 inches in the rear. I'm running bilstein 5125s which had to be modified to fit as they are not specked for the ram. I had to change the bushings to accept the stock mounting hardware
1SloRam
Ms
Can you send me some pics on how you did this?
