Lucas Oil Synthetic Oil Stabilizer
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
What kind of drain intervals are you doing? You should not notice much loss in 4 or 5k. If you are doing 10k you will.
$miley
t.links
i
I have tried this it did not work.i have used lucas in all my trucks never sold truck with under 260,000 miles.in my tests with getting rid of tick is i run gtx 5 20. i no longer have tick.lucas made tick louder with about 1800 miles on oil.i also started only putting sunoco 91 octane at same station every fill.tick been gone about 6 moths.knock on wood it drove me crazy.hope this helps.
Belgiquebasterd
Inertia 392
Finally replaced the oil at 100,000 miles. Did it immediately after arriving at home to see it there was any foam in the hot oil. There was no foam whatsoever. The stabilizer did assist with cold starts since it's getting into the winter months in PA. It also extended the life of the oil. Normally the oil pressure gauge starts to decrease on startup position around 7000 miles but now it stays constant the full 10000.
Don't exactly get what you mean by the oil pressure gauge, it's what they call a dummy gauge, whenever the oil pressure is within a certain range the needle stays at the same position, whenever the value is outside the range the needle either reads high or low, there is no inbetween?
Or do you have an aftermarket gauge fitted?
From the manual:
² Engine Oil Pressure Message - The instrument
cluster circuitry restricts the oil pressure gauge
needle operation in order to provide readings that
are consistent with customer expectations. Each time
the cluster receives a message from the PCM or ECM
indicating the engine oil pressure is above about 41
kPa (6 psi) the cluster holds the gauge needle at a
point near the middle increment within the normal
range on the gauge scale.
² Engine Oil Pressure Low Message - Each
time the cluster receives a message from the PCM or
8J - 32 INSTRUMENT CLUSTER DR
ODOMETER (Continued)
ECM indicating the engine oil pressure is below
about 41 kPa (6 psi), the gauge needle is moved to
the graduation at the far left end of the gauge scale,
the check gauges indicator is illuminated, and a single
chime tone is generated. The gauge needle
remains at the left end of the gauge scale and the
check gauges indicator remains illuminated until the
indicating that the engine oil pressure is above about
41 kPa (6 psi), or until the ignition switch is turned
to the Off position, whichever occurs first. The cluster
will only turn the check gauges indicator on in
response to an engine oil pressure low message if the
engine speed message is greater than zero.
iJacob
Gonna try it Friday
iJacob
Should I do penzoil platinum 5w20 ?
iJacob
Well it seemed to work 1 1/2 qt of lucas and the rest valvoline high milage oil. 5w20
OCDTech
Louisiana
no do rp i do amsoil no problem but only 59600 miles on mine !
Sir, i'm writing this with best of humor in mind i promise. But if he doesn't have it figured out by now, he probably wont. That post is 5 1/2 years old.
But definitely thank you for trying to help.
Why did i notice this? Because yes i have done it a few times myself.
Reactions: U&A
U&A
2016 3500 SRW
6.4 HEMI
Iv done it too.
No harm no foul right...
But sometimes I do it intentionally to bring up an old but good topic.
Sent while firmly grasping my redline lubed RAM [emoji231]
OCDTech
Louisiana
Iv done it too.
Absolutely!
scott lass 18
rocklin ca
2010 ram 1500
so now 2020 ya a ticking going on one exhaust replace this year and fuel injector went bad ! stealer says other is ok owwww a lifter ? TIC TIC TIC BOOB ! luckis has help it get less noisy so well try redline oil soon on mine ! 61.000 on her sad all going on now stalls at stop sign not sure why yet ! low miles and this going on so sucks !
