Lug Nuts
wrigley
2023 5.7L Bighorn 4X2. Want to change lug nuts to all one piece. Recommendations please. Thanks
MADDOG
Living in a Firepit
You'll need a thread spec M14 X 1.5 nut.
I'd measure the length of what is on the truck now and record that info.
Then ask Benny at AllMoparParts (a vendor here) on what one piece lugnuts are available through him.
Or you can go to Gorilla Locks or a similar aftermarket firm for locking lug nuts that meet your vehicle's spec.
Magfan2
Montana
Those wrapped lug nuts caused me trouble several times in 20 years with a Magnum R/T. When I replace the tires on the 2014 Ram Sport, it will be with one piece lug nuts as well.
Daw14
South Florida
I’ve been using Gorilla for 11 years now and they have held up well. They do have light surface rust but it’s not bad.
I would look at Mcgard lugs also , they have been what came on my last two new trucks as locking lug nuts. None of these has any rust .
Cedar Lake, IN
Good luck. I just went through this and everybody I talked to says lugs are all junk now. Except for maybe genuine Mopar, but they are crazy expensive. Fun Fact! - Many, maybe most, lug nuts have a note inside the box that says do not use an impact, hand tighten only. Yeah right. Finally I just said the heck with it and bought a cheapish set off Amazon that are the correct size. They are slightly longer than stock, but I had some non-stock nuts already and never noticed until they started looking rusty. So current plan is to replace as necessary. I got 17 spares. Prob outlast the truck.
4xdad
Edmonton Alberta
2015 powerwagon
Imho do not get lugs that you need a(key ). Regular lugs won’t leave you with 7 nuts off and 1 nut you can’t get off because you lost the key.
murderman
Cummins 6.7
I've had good luck with Gorilla Lugs on my truck. They changed the model number from what I have but these are the new ones: https://www.gorilla-auto.com/gorilla-automotive-66148fs
So far they are holding up well to road salt and being on the coast.
I just installed those exact lug nuts on my 2018 2500 last week. I got tired of those POS OEM lug nuts getting stuck in the socket when removing to rotate my tires.
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
stevenmicheal
