Mag-Hytec Diff Cover and 2” Rear Lower
ameldorf
Lenoir, NC
For my 4” drop in the rear, I had to cut the front spare tire stop off. It was hitting my Nitro diff cover.
Before
After
Milspec
Milspec
Before
After
Interesting, thanks. I can’t imagine a simple 2” rear drop would affect the cover...
ameldorf
Lenoir, NC
Not sure, but if you hear a loud knock or bang from the rear, you’ll know for certain.
To avoid the possible destructive test, you could measure from the bottom of the curved piece to the top of diff cover and then measure from the axle plate to the bump stop cup. If there’s more clearance on the diff cover to curved pice, you should be in good shape.
Milspec
Milspec
You know what, you’re right! I just now realized that the “U” shaped piece from that old thread I pasted in is referring to the piece you cut off and not any part of the actual diff cover.
I was just staring at the pic of the diff cover and scratching my head on where the hell there’s a U shaped piece. Appreciate your insight!
lonsloo
Lakeport cal.
I just installed my McGaughy's 2x4" drop now I ready to install the IHC no cut brackets can you tell me where you bought your adjustable Panhard bar and what sway bar and bushings are you using? thanks
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
When i installed the Mag-Hytech cover
the salesman told me that under some conditions
The sway bar may need spacers behind it
He never mentioned trimming anything.
It is true that the spare tire equipment could get in the way
Milspec
Milspec
Good to know! I will be dropping I just don’t know if it will be a 2” rear or a 2/4. Need to swap my driveshaft before anything else tho.
M27
SJ,CA
I did a 2/4 drop without removing the rear bump stops and that ‘U’ shaped piece and I would get a violent bottoming out on big bumps or dips. After driving for about two months I recently got my truck on a lift to check where it’s hitting and the no cut brackets are hitting the bump stops and that ‘U’ shaped piece is hitting the diff.
6speed4.7
Winnipeg
If you don’t have the Air Lift bags maybe it’s time to get them
I have the no-cut brackets and shorter bump stops and have carried 1500LBS+ in the box and haven’t hit the frame rail or diff- bags pumped to 30psi
Reactions: M27
t0ymach1n3
Dallas, TX
5.7L???
Gonna add to this, in case someone in my situation comes across this:
I have helper bags, no cut brackets, and all the goodies everyone rants and raves about. I just noticed tonight my diff cover was getting hit. I do not have bump stops in the rear and will be cutting that piece off to avoid any serious damage as Dallss, TX roads are crap!
