I believe you need need part no. 10778. Dual Inlet 2.5 in., 3 in. Single Outlet. Just verify with Matt before you order.
It would be nice if someone made a piece that didn't require any custom bending just cut and weld
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
I'm not buying the +8 HP on this mod alone (on otherwise stock truck). Links to that thread (guess I can search.)?
That was posted on another forum, by a guy who's heavily into the performance aspect of our trucks. They did a before and after on a 2004 Hemi.
It makes sense the exhaust note is quieter. You have two pipes entering the Mag Y into a generous chamber and out a 3" outlet. The exhaust through the new y-pipe is more free flowing. If you check out the pics of the stock Y, that's basically two pipes split in half and shoved into one.
Chuck,
It's more than likely going to smooth out the tone. You'll have a system that will flow better with the Y. My truck's exhaust was a little heavier at idle before the swap. I personally think the Y complements any exhaust upgrade.
Sil
great Sil, thanks for your input. I suppose i'm willing to sacrifice some of the growl if it provides a decent power increase.
My pleasure Chuck.
I don't think you'll lose as much sound as you think. Under mid to heavier throttle your truck will still sound very aggressive. Mine does for sure. I have a video somewhere on the forum, with windows up, and the exhaust still sounds great.
Definitely post some pics and vids of your setup!
The bigger MAG may end up better for you. Especially when it comes to drone. Nothing worse than a droning exhaust. It gets old quick. I had my exhaust guy move the muffler so it's sitting just under the bed. This helps with drone.
