Manifold bolt cost
blrmkrl83
Iowa
I've had a leak on the right manifold for a while now. The left one just started leaking today. I was curious what everyone has had to pay to get their trucks fixed.
Eased
Canada, eh?
2014 1500 Sport
5.7L V8 HEMI
Most often caused by broken bolts. Extract any broken bolts and reinstall the manifold with new gaskets and studs for both sides.
Part 5045496AA - Gasket Right
Part 5045495AA - Gasket Left
Part 6509544AA - Studs
Kap1
Ex Ram 1500 2013 owner
2022 Tundra
3.5 vvti
It depends how involved it is, and if any bolts break during the service. Try get a flat fee repair quoted, so in case bolts break, mechanic won't charge you a lot extra to finish the job. Also ask to make sure that heads will be machined to make sure that they're not warped and you won't get same issue again. Ask if they machine heads in house or send it to machine shop, this is critical to make sure it won't break again. Ask about warranty in case it starts leaking again.
Looks like you need both right and left sides done? I had mine done under powertrain warranty, but my guess that it probably would be less than $1k to get both sides done... Just a wild guess.
Ramnewbie
Why are you machining the heads, I thought it was the exhaust manifolds warping that caused the studs to break.
Sent from my XT1650 using Tapatalk
tantore
texas
birmkrl83 dont waste your money fixing the old manifold get a good set of headers for about 700.00 and you will not have the broken bolts any more try moe's performance for a good deal
Nick@GotExhaust
Supporting Vendor
SC
you can replace with shorties or go big and do some long tubes! Let is know if your interested. we are running 20% off Stainless Works!
Kap1
2022 Tundra
3.5 vvti
Sorry, yes you may be right. I may have confused it
jvbuttex
I-6
as said, make sure the head and manifold are still flat. Chances are the head is fine. Mine developed a leak from broken bolt on the pass side. Dealer ended up replaced 2 bolts and the manifold. It was warped.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I highly recommend getting rid of the manifolds and going with a header. I lost count but I believe I had both sides done on different days around 93k and 95k. Mine need it again around 30k later and I just changed to headers. Those manifolds are complete garbage they warp and then snap the bolts right off especially in the back.
AzCats
Portland OR
2014 1500 CC Laramie
Is this true about the headers? Anyone with headers installed no longer have broken bolts/exhaust leak issue?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
So far my headers are working well. My theory is the material used for the headers is less able to snap off the bolts since it is not cast iron. Cast iron is so strong it pops this bolts/ studs right off. I also went with stage 8 bolts so I don’t have the best science experiment since I changed two things I won’t know exactly why it is better. I also used new factory gaskets.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Smiley did you go LTs? And did you do em yourself or send it out? I have my LTs in the garage, ceramic coated, got remflex gaskets and Stage 8 fasteners but work schedule is eating into my DIY time. I am looking for folks who ran LTs, ideally 2009-2012 and have a good workaround for the oil dipstick tube.
Right now I am a :chicken:
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I paid to have my mechanic do it. I have shorties from BBK. He modified my dipstick tube to make it work.
Ramnewbie
Where the shorties just a bolt on change or did you have to modify anything other than you're dipstick? Also was there any computer changes required or can you run a completely stock tune with no codes?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
You can run shorties with no tuner, I have read they are good for about 8hp.
I believe they are a straight bolt on.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Just bolt on my mechanic said they were a ***** to put on. Maybe I got a bad batch but it sounded like he had to loosen motor mount to do the install.
AzCats
Portland OR
8hp? seems low... do you know what the ballpark would be for a shorty and tune?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I do not, Long tubes are the way to go if you are going after big hp gains.
I am sure with a good tune the shorties would make better numbers.
AzCats
Portland OR
Wish I could but long tubes would be a big no in California SMOG. JBA shortys are my only option.
bassheadhemi
Montreal, Canada
The reason he had to loosen the mount was to get to the bolt that hold the dipstick tube.
Sent from my SM-N950W using Tapatalk
