Can somebody give me some info? Pulled power seats (Driver and Passenger) from 02 Ram 1500 SLT w/connector. Wanting to install into my 05 Ram 1500 SLT What I need is to understand what all the wires are for from the Cab Side of the 02 Ram Connector. Any help in this matter would be greatly appreciated.
The 2002 Ram 1500 factory service manual is available in the 3rd Gen DIY section. It is available to download as a PDF. I can also send you a link to my OneDrive account if you want a quick and easy download. You can view the complete wiring diagrams and connector pin-outs for the body-side connectors.
Appreciated but now i'm more confused than ever because I don't understand all this. my 05 Had Manual seats (Cab side connector has 4 wires). I just want to simply get the Power driver seat that I took from the 02 Ram to move forward/Back/Up/Down. If I run a 12 Volt Constant to the Power Seat will it work?
Yes, if you run a B+ battery power wire to each motor along with a ground the seat adjuster motors will operate. I would run a fused power wire to the motors and a switched ground to them as well. That way the seat adjuster motors will have battery power supplied at all times and the switched ground will apply the ground to the motors for normal operation. Get out your test lamp and find which one of the wires in the connector are hot at all times and use it for your power source.
