MDS delete kit PCM
Lester07
Savannah
5.7L
Hey all! Hope all is well. New to the RAM forum here. Hope someone could help me. Just installed a MDS Delete Kit & inTune i3 w/ PCM Swap for my 2016 5.7L from AMS racing. Just waiting for the PCM to come back. My Question, Can I start the vehicle with the original PCM so I can flush the radiator and Oil until I receive my Nee PCM, Thank you! V/R Lester
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Wish I could definitely say yes or no (never heard that one before), but, since MDS doesn't kick in till it's moving somewhere over 35 mph, it should be OK, since you aren't going to be driving it.. You can also turn on tow / haul mode, which locks out MDS, I believe. Also, the gear select buttons on the steering wheel lock out MDS if truck is in drive..
Lester07
Lester07
Savannah
5.7L
Thank you all for the quick responses and glad to be here.
NCRaineman
NC
2019 1500 Classic
MDS isn't on at idle. I wouldn't drive a lot on the stock PCM but you can definitely run it in the driveway for a few minutes. Heck you can use the + & - buttons on the wheel (or shifter if you have the older 6-speed) manually select top gear and MDS won't turn on. I've been doing that every time I drive our truck for nearly 5 years. Not sure why people pay $$$ to "delete" a feature which is disabled at the touch of a button.
04fxdwgi
2016 1500 Sport
If you do run it on the old PCU in the driveway, I would expect you to to see an MSD CEL because the solenoids aren't there any more (or did you leave them connected, but not mounted?)
Lester07
Lester07
Savannah
5.7L
Took out the solenoids. They are not connected anymore. I used plugs that are designed to plug the hole where the old MDS solenoids used to live. It’s used when swapping MDS engines into older non-MDS cars or retro fitting non-MDS cams.
6 speed Challengers also use the plugs,as they're non-mds engines
04fxdwgi
2016 1500 Sport
Yeah, I figured that. I have heard of a couple of guys that left the solenoids connected to the harness, but not into the oil gallery (plugs installed) for some odd reason. Perhaps it was to fool the CEL.
