DeckArtist
I have heard somewhere that the MDS wont work unless you use 5w20--does this mean that I can use a different oil weight and the mds wont come on again? That would be a great solution-but will I damage the engine-The 5w20 is damn thin and doesnt last long especially in hot climates,Its great for cold start-ups but doesnt cling aswell as a thicker oil. Does anyone know if the mds doesnt activate with a thicker oil or would this create issues?
I’m running 5W 30 and mine still works so that’s probably not the fix. I disable mine by the gear up and down buttons before each drive. Slight hassle but I’m getting used to it would love to be able to turn it off with a gizmo like the one posted above that leaves no trace and doesn’t alter the turn from the factory.
