mesh grill price?
ram_tech
was looking online on the solid black all mesh grills for my '15 and they where all 6-800 bucks.
am i looking in the wrong places or are these over rated peices of chicken wire realy 800 bucks. and there not even a full grill you gota cut yours to install the mesh.
kg93
AZ
Wandell
Cummins 6.7
I like the mesh grills, but they are way overpriced. I finally ordered an insert from E-autogrilles on Ebay. When it arrived, it was actually a Smittybilt grill.
hemi1282
Arkansas
2016 Ram Tradesman
Ya Im'a have to get me one of these, I seen a couple at 4wheelparts store, gettin some rims from them next weekend probably get'em to install one of the m1 grilles, think it was around $300 there
JGBimle
Just ordered an Eautogrill from eBay for my 15. Pretty pumped to get it. I love the look of them. Any tips or explanations of the install on these inserts?
BlownGP
Houston/Baton Rouge
They really are. Pretty nuts for mesh grill to cost almost $300
poweredbyhemi
Was going to get a grillcraft but the mesh is so small you can hardly tell its mesh & i found it for around $260 delivered.Then theres the solid mesh that requires cutting of the grill & i still have one in the box for a superduty as it's a pita to install or @ least that one was going to be.
LB3711
Trumbull, CT
3.6L V6
It isnt that bad. So you want something like my hood scoop? I had to cut my grille too.
Here is a closer higher resolution picture of the grille. Click it to see.
Rzrman328
The treeline
I think your grill is one of the best looking out there.
I'm tryin to figure out a way to make my own lol
charonblk07
Calgary, Ab
F1-A forged 349ci
You would be amazed at the price of mesh sheets, and I'm not talking the cheap expanded mesh, the hexagonal or welded woven mesh that's good quality. My sheet of steel 1/2" hex mesh I bought was $250 for the material alone. Most are overpriced, I had an RBP grille on my last truck, poor quality for way too much price.
floridapete
RzrMan -
I have made a ton of grills in the past on my own - relatively easy once you get the hang of it, and learn to work with the wire mesh material. I usually start out with a sheet - something like a 24" x 48" - Custom Wire Cloth - Belleville Wire Cloth Co - Cedar Grove, NJ .
Make sure to get aviation snips - they are really the only way I had any luck cutting this stuff. Also - a side note - make sure you use stainless steel! I wanted the black color and used plain steel by mistake - the salt water rusted this grill almost instantly.
alphaprojects
