Mevotech Question
jgruberman
EcoDiesel 3.0L
Was looking at leveling, tires, UCAs, the whole thing and I wanted to make sure I had the right UCAs for a 2015 1500 4x4.... Mevotech part MS251057 and MS251058?
What are the parts for Zone UCAs just in case I want to go that route?
fordtech90
Jonesboro, La 71251
Perfect choice. Be sure to post pics when it's all done. And also install pics if u do it yourself.
jgruberman
jgruberman
EcoDiesel 3.0L
I will do all of that. You say perfect choice to the 2.8 Bils front and 1" spacer in the rear?
jgruberman
jgruberman
EcoDiesel 3.0L
Any particular brand of coil spacers in the rear? I figure a spacer is a spacer... But thought I'd be smart and ask just in case...
sbuko213
Arcadia, FL
6.7 HO
I kinda like mine no spacer in the rear. I may be burned at the stake for saying that but it's personal opinion.
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Those part numbers are correct for the Mecotech's as I just ordered mine. :)
Adam
Ram75
South Jersey
2019 Tradesman
Any specific site you guys ordered them from?
matt.davidson09
2013 RAM 2500 Laramie Mega Cab
6.7L Cummins
So...probably should have asked this question prior to placing my order on RockAuto.com; but are these Upper Control Arm part numbers (MS251057 and MS251058) the same if I have a 2WD?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
yes, same.
tdramman
Georgia
2015 Ram 1500 Laramie 4X4
So I pulled the Mevos from the box and painted them but forgot which box they came from. Is there a way of telling which one is for the drivers side and which one is for the passenger side?
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Yes.... one end has more of a curve than the other. The other end has more of an actual "bend" in it.... if you look closely, you'll see the difference.
picture.php
On the passenger side, the front has more of a curved support where as the rear has more of an actual "bend" in it. Hope this helps!
Adam
