Mileage meter is not accurate.
dpinvidic
This guy gets shotgun
Cave Creek, AZ
2014 RAM 1500 Limited
Has anyone checked the accuracy of their MPG reading on the truck?
My 2014 Laramie is consistently reading about 1 MPG higher than actual.
Filled up today and the reading was 13.6mpg
Did the calculation and it was 12.76
I have been trying to see if I get better mileage by using premium fuel, and have noticed this on the last three fill-up.
Dan
Dante221
Ardsley NY
Hemi 5.9
Good enough .....
Dan
....for government work!
:big_banana_Dance:
Dante :waytogo:
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
The silverado I traded in on my ram actually was consistently within .1 mpg of hand calc'd
I wish my Ram was even remotely that close....only thing I miss about the chevy.....that, and the headlights that were 100x better
Ocelot
Hand calculating mine shows the Average and DTE is really close on mine. Usually between .75 and 1 MPG. In my book, that's really close. I do notice that it's most accurate when I fill the tank, which is most of the time. When I occasionally put in less than a full tank, it's over 1 mpg off.
Ray
dpinvidic
dpinvidic
Cave Creek, AZ
Anybody got a take on using premium gas to get better mileage?
Does mileage improve enough to justify the cost.
Before I knew the readings were off, I needed .6mpg better to make up the cost.
Now I need to recalculate.
Dan
granite14
Portland, OR
2014 Ram 2500, 4x4, CC, SLT Big Horn
I would think that the accuracy of the EVIC would be better than the uncontrolled variables from pump to pump and day to day
- the amount of vacuum in the pump to cause it to shutoff or not
- the temperature of the gas already in the tank and in the ground tank
(higher temperature = more volume, which will make the pump shut off faster).
snopes.com: Tips on Pumping Gas
dpinvidic
dpinvidic
Cave Creek, AZ
In Calif. this stuff is checked on a regular basis by the Weights and Measures guys. They make sure that the gallons dispensed equals what is read.
There is some kind of disclaimer about the amount of energy varies based on temperature.
What the Snopes info says is likely true, but my opinion is that it really only amounts to a few cents. And if I always buy gas at the same Costco (which I do), then temperature and other variable are fairly consistent.
Here are some details that explain why the vehicle gauge is not accurate...I learned something today from this,.
Your Fuel Economy Gauge Is Fibbing
Dan
granite14
Portland, OR
Dan
Good to know. I would think wrong :fca5278e:
mjd91
San Marcos, TX
I've checked mine multiple times in the almost 6 months I've had the truck and every time the actual is right at 1mpg lower than the computer reads.
Close enough for me!
It's been the same enough for me to trust it.
WhiteExpress
Midland, TX
My EVIC is always optimistic.
Even averaged out over the past 4,000 fill ups (or 20 miles, whichever came first) I get worse MPG ever time.
DannyMK2
Long Island, NY
2015 Power Wagon
Dan
i see no difference in fuel mileage or power between 87 and 89. never though about trying 91 or 93 because of this. maybe if i had a tuner that could make use of the higher octane fuel, but that would be more for the performance aspect...i doubt i would realistically see an increase in fuel economy. it would probably go down because my foot would always be in it.
granite14
Portland, OR
On the trip meter B, if I reset it often to measure different types of trips, I consistently see EVIC at 1MPG below hand calculated for the tank.
I just ported my data in Fuelly, and it is calculating 11MPG total since my truck is new (some towing). The trip A has never been reset, and it shows 10.8 over the same distance. That's pretty damn close.
smokinstorm
OBX, NC
Oh well, there goes the gas mileage I thought I was getting. The DTE when I fill up shows almost the right number though???? Lots of variables between when I fill up and when I burn the tank out. I've never filled the tank and driven it out without stopping. It's usually a couple of weeks and 600+ miles between fill-ups for me. And a mixture of all kinds of driving in one complete tank.
NewBlackDak
Hemi 6.4L
I haven't had the truck very long, but the EVIC has been within .1 of what fuelly calculates every time.
loveracing1988
Clarkston, MI
Want to trade trucks? I would love to go 500 miles on a tank of fuel, let alone 600.
truckin289
My guess is he has the 32 gallon tank option.
I hate when people start comparing how many miles they get to a tank... that doesn't mean anything unless you are 100% sure you have the same vehicle with same tank size. What matters is MPG!
