Mirrors
jknappen
Kentucky
Have a mirror that is messed up (drivers side) was wondering if I could swap out both of my current side mirrors with ones with turn signals. I have the mirrors that are power with heated capabilities. can they be swapped with simple plug and play?
bobbo7915
Massachusetts
CTD 6.7L
this has been talked about a bunch....i was able to swap from the standard power/heated mirrors to the tow mirrors with blinkers and puddle lamps. it is a simple swap, plug and play BUT the blinkers and puddle lamps will not work until you have the dealer flash sales codes LEB and LEC.
jknappen
jknappen
Kentucky
Does anyone know the part numbers for the mirrors that are paintable? And the part numbers for the towing mirrors that will fit a 2013
carid
Cranbury, NJ
Hemi 6.1
jknappen, you can check Replace side mirrors: Replace® - Dodge Ram 2013 Side Mirror They can be power, heated, with turn signal, but they already come in Chrome finish, so you won't be able to paint them. These are direct replacements for factory originals, you can check if they are compatible using OE#.
jknappen
jknappen
Kentucky
dont really want chrome would rather have them match the truck if possible
