negative_creep
2010 5.7 hemi has misfire on cylinder 6. I've replaced spark plugs, swapped coil pack to different cylinder, new boots for #6, new fuel injectors, tested injectors with noid light, replaced pcv valve and camshaft position sensor, compression test was good. Could this just be electrical problem? Possibly ECU?
