Mopar oil filter or K&N...
BlkPearlSport11'
Cresson,Tx
2011 Black Sport Quad Cab 4X4
Anyone here use the Mopar oil filter or know the K&N oil filter part#? I am going with Royal Purple and a dealer parts Mopar or a K&N filter from Orileys anyone know the part # or if there is one lager to use? truck is 5.7 2011.
quietpeen
2021 TRX
Hellcat
I do not know the part #'s, but hopefully somebody that does chimes in.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Checked rock auto for a number for them and came up empty on the OEM number just the Wix, Fram and Auto extra part numbers. I wonder if its still using the same as the 3rd gen hemis. I honestly havent looked under a 4th gen to see.
BlkPearlSport11'
BlkPearlSport11'
Cresson,Tx
Called Orileys and they gave me part # HP 2010 for the K&N filter. But anyone know if there is one that is a little bit longer that will fit over stock size?
BlkPearlSport11'
BlkPearlSport11'
Cresson,Tx
Just bought the K&N HP 2010 it's bigger than I thought!
09SMOKINHEMI
TEXAS
what does a mopar/k&n filter do that others don't? is it what's needed in order to use royal purple?
txbass06
NE Texas
5.9 Magnum
The K&N filter has a higher filtration percentage than some other brands. They also have a 1"(I believe) nut on the bottom that you can use a socket or open end wrench to tighten and remove the filter
Sent from my iPhone 4 using Tapatalk
WhiteExpress
Midland, TX
K&N and Mobil 1 Filters are identical internally. The K&N has the nut on the end which is very helpful in some applications. This will be my first change, so I don't know if it's helpful or not.
09SMOKINHEMI
TEXAS
cool, makes sense.... I learn something new everyday
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
The reason he mentioned filters and RP is when you buy better oil you can run longer intervals if you have a higher quality filter you can then go longer between changes. This is the principal behind Amsoil. Which I use and Heath sells as a preferred vendor on here.
$miley
09SMOKINHEMI
TEXAS
being new on here, I don't know who Heath is.... could you point me in his direction?? I'd like to start using that on my Ram. I purchased it last weekend, and has 13,500 miles. I'd like to use it on my wife's BMW X5 too if possible.
quietpeen
2021 TRX
Hellcat
here click on the link. Its the Amsoil vendor section. Post a new thread asking for what you want.
Amsoil - DODGE RAM FORUM - Dodge Truck Forums
BlkPearlSport11'
BlkPearlSport11'
Cresson,Tx
Trust me the nut on the K&N HP 2010 is verry helpfull on my 2011 4X4!
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Get 0W-20 Signature oil from him you will never go back to anything else. Yes it works with MDS If you still have it on. Great for cold mornings too!
$miley
ChloeBrooks
