Mopar Splash Guards
RamGuy110
2022 Ram 2500
Does anyone out there have the Mopar Ram Heavy Duty rubber splash guards on their truck? Specifically the the ones that say "Ram" on the bottom and vertical lines/bars above. If so, please post a pic.
I'm wondering if you can mount them so they poke out just slightly for a little extra coverage?
Firebird
2019 Ram 2500
I have them, will take some pics this morning
retired
montana
They are made to fit a specific way. If you try and reposition them they won’t fit right.
Papa Red
Papa Red
Nebo, NC.
I have them too. They stick out at the top by a good inch. Very easy install since they use the existing screw holes.
Red
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
I don't like how they stick out, but I understand why they do. I might put the rears on my truck just to keep the rocks off my boat.
retired
montana
they don't stick out so far if you have factory flares. They help a lot.72A1C1CB-C3F0-419F-831F-D7F163B2F492.jpeg
Dean2
Near Edmonton
The Weathertec fitted flares are a much better fit on my 2500 with factory flares. No drilling required but I would suggest using some silicone sealer when you put the screws back in place. I put the Weathertec on after test fitting the Mopar ones. The WT were also a bunch cheaper than the Mopar.
RamGuy110
RamGuy110
2022 Ram 2500
I just picked up a full set. Not installed yet.
Papa Red
Papa Red
Nebo, NC.
I went with the Mopar flaps partly because they are rubber and flex if you hit something instead of bending and possible ripping off. Easy install and they look great.
Red
Firebird
2019 Ram 2500
Red
Your truck looks fabulous with the 8’ bed!!
odinjunior
Az
I just ordered a set of DuraFlap extra log for the rear. Gotta protect that RV.
odinjunior
Az
I'll be mounting my DuraFlaps next week. I'll post pictures when done.
