nick00less
- Jul 21, 2017
- 59
- 17
- 2017
- Diesel 6.7
The purpose of the relays is to deal with the PWM provided by the BCM to the low beam circuit by getting a consistent power source for the ballasts straight from the battery. The reality is, it’s the relay harness and resistors that are the band aid. This is why hid kits are sold as bulb, ballast, and igniter. Then, as optional equipment, the resistors and relay harness are offered as a band aid to deal with picky vehicles. The actual fix is to change the truck’s programming to shut down the PWM in order to provide the ballasts with consistent power, therefore negating the need for the optional equipment. This is the very reason that FCA built the HID headlight feature into the BCM.
Now, if one were using 55w ballasts, then it would be a good idea to stick with the relay harness. But, 55w ballasts aren’t worth the hassle because you get barely noticeable output gain at the cost of wasted energy and unnecessary heat put on the wiring and connectors, and the fact that they’re marketed towards those that think bigger is better.
Your gah damn right. TRS Kit IS THE BANDAID. When will people finally realize you don’t need bandaid wiring kits on these trucks anymore?!??
I too changed my BCM in my 2018 to enable HID’s. Guess what folks. That special 2015+ mopar harness is in the trash.
My trucks headlight harness is now DIRECTLY connected to my ballast. No special harness. No nothing. I’ve had zero issues since switching over and I’ll never go back.
I’m not the only one either..more people are coming to the light.
