mounting amps??? where?? how??
clays laramie
hemi
Any pics of amp installs..how are people securing there amps.. i plan on mounting mine to mdf..but then what...velcro under the seat?? What about behind the seat?? Dont want to drill into the body. Diy threads???
Hipps2000
2013 Ram 1500 Bighorn
Hemi 5.7l
I have been researching the same ideas for My build and install. I have found some great ideas as well. Here is a pick I found on MDF with metal bracket that utilizes the child safety attachments behind the seat. No drillin very stout. Also has a bracket on bottom the attaches to seat bolt brackets.
Hipps2000
Hemi 5.7l
Here is a pic in the truck.
clays laramie
clays laramie
hemi
Wow.. amazing job... im just doing a sub amp right now.. but im sure i will be doing more later...nice setup.
Hipps2000
Hemi 5.7l
Yeah I thought it was really nice work. This is not my build but I like the idea of running mdF across the whole back and fastening into the child safety and seat bolt mounting points. I then would be able to add foam and deadner to the back help to reduce roadnoise.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
that there is a nice set up!
I only had 2 amps to put in. I put one 4 channel under my drivers seat on MDF board with Velcro on the carpet side. covered the sides of the amp/mdf with color match felt sub box carpet.
The other, I actually removed my center 40/20/40 armrest/console (just the padding not the whole frame) and put the sub amp under there. I installed an LED light strip as well while I was at it to not only tell me the sub is powered on but to give some ambient foot well lighting. waited to dial in the sub level and crossover then reassembled the seat cushion.
DavidRam
SoCal - Redondo Beach
2012 RCSB
That does look really clean. I put my amps under the seats and the dsp is under the dash on the passenger side (see pic).
Second pic is the back panel, it might help with ideas... Oh, don't forget sound deadening. :favorites13:
woojyee
Nebraska
Hemi 5.7 eTorque
My JL Audio XD700/5v2 in the center console compartment under the center seat.
woojyee
Nebraska
Hemi 5.7 eTorque
Looks like my old set up in my 06 sierra crew cab
crappy pics but here is a few, i did have the other cap for the end of the amp just wasnt in the pics
A Rockford Fosgate Stack! reminds me of my 02 Silverado build... I wasn't too concerned about making too pretty since it was hidden behind the seats..lol
I still have the truck and the stereo gear works perfectly after 12-years. Just had to replace the JL Audio sub cause the foam surround disintegrated but learned later I could have had the foam replaced.
lilzilla2008
Nice! Mine worked absolutely perfect and when I traded in the truck for my 02 Saleen I smooth forgot to take it all out. When I realized it a week later I smooth kicked myself in the ass about it!
The thing I liked about mine is I lucked up and found the actual link with the volt meter. Was a killer setup and I'm considering buying another one of those Amps for my ram
Bunwich
