Mpg spike?
Litew8
Near Youngstown Ohio
4.7l
What would cause my not display to jump. Like crazy. I normally reset at full ups and i get 15 mpg. But sometimes crazy things happen and it shows 20 mpg. There's no way. I have a 4.7l lifted with 33" mud tires.
Sent from my LGLS775 using Tapatalk
BAMF
Southern Louisiana
2015 Big Horn
Mine is stock lift but 33s....i get 20-21 consistently
Sent from my SM-N910V using Tapatalk
Kapt
3L
Whenever I reset mine and go straight to highway driving it always says stupid things like 87mpg until it evens itself out
MarshRam
2014 SLT 4x4, 2012 ST
If your driving pattern and style are fairly consistent, that is quite a gap. Obviously there are other conditions such as weather (wind and temperature) that can cause variances. I have read that avg. mpg on many vehicles is incorrect as it seems the technology is just not there yet to accurately accommodate all the variances. If your speedo is calibrated it is best to hand calculate rather than rely on the lie-o-meter. I just got my truck calibrated and on the first tank avg. mpg was 17.1, but hand calc was 15. I will be hand calculating moving forward as I play with the different tune options and continue to add my final exhaust upgrades. I would suggest you hand calc to see if you are really experiencing a gap. Had a bad misfire on my last dodge, but the mis was reducing my mpg by 1. However, I wasn't hand calculating, so who really knows..
Rzrman328
The treeline
Yep, they adjust.
Mine sometimes says 300 to the tank after fill up.....that's just nonsense.
Litew8
Litew8
4.7l
I understand that. I think something is faulting out and giving a false reading. Cold start in the weather after hitting the remote start and it will be at 22mpg when normal it would be going down not up.
huntergreen
Marine Corps Navy Badge
I would think driving conditions and style affect read out. Keep driving and it will start showing s more accurate reading.
Litew8
Litew8
4.7l
Normal it's around 14 to 15. A blue moon happens and I'm getting 22. Thinking there's an issue. Hoping someone will have an
ScottFL
U.S. Navy Gulf War Vet
2016 RAM 1500 Laramie Longhorn 4X4
HEMI 5.7
Create a Fuelly account LINK and keep track of every fill up and actually know what your truck is doing, not the lie that your truck is telling you.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I noticed after towing a trailer mine gives abnormally high readings but eventually levels out...
