Mpg
Easygoin
Salem, Or.
I have a 2011, 5.7 with the engine management system. It runs great and I truly love the truck, first Dodge PU I've owned, but 11 mpg seems excessively bad. The only mods are the 35 inch tires on factory 20 inch wheels. Somebody please tell me there is something I can do to improve the mpg. Any constructive input would be appreciated.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
That's as good as you will get around town ... you might get int he high 13s if you do a lot of freeway driving .. also if you have the stock gears, 3.21s, 3.92s , you are not going to get the correct MPG ....
With 35s you should really consider regearing to 4.56s if you want to improve on your MPG and also correct the speedometer if you haven't already ...
E
Easygoin
Salem, Or.
I have only had the truck a few months now. I was planing on replacing the 35 inch tires with 33s when they need replaced. Not sure how to go about finding out what gearing I have. I drive the truck very little in the summer, but will use it almost daily in the winter. Golf course, 15 miles of highway and small boat to the lake, 60 miles of highway. It has so much power I don't think re gearing would hurt around town performance, but might really help the highway mpg. I'll look into. Thanks
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Go back to 33's & a highway tread if you are concerned with mpg........a lift & aggressive tread/heavy tire will cut 2-4 mpg is a fact......
UnleashedBeast
Pensacola, Fl.
2019 Classic Big Horn
Agreed, that is the problem. The lift kit and heavier 35" tires are killing your mpg. Lower the truck to stock height and return to 33" street tread tires to increase it.
Black1500Ram
Scottsdale, AZ
Be careful about wheel and tire selection also. 17’s will be much lighter than 20’s (I’m currently in the midst of that swap). Tires are about a wash weight wise at 55lbs for LT tires.
You can get passenger tires if you’ll never go off pavement but buyer beware. They will be about 10lbs lighter per corner but you’ll be susceptible to flats much more.
Nova John
South Plainfield New Jersey
This is my third Ram in 17 years. Have intake, exhaust and canned tune on a 2 wheel drive short bed truck. Gas mileage is 16 around town and 21.5 highway. I also have 392 gears and 265/70/17 tires. My son has 2014 Ram club cab 4x4 and got decent mileage until he went with 35 inch toyo's and a slight lift and leveling kit. He lost between 3-4 mpg. I guess the extra tire weight and lift raising the height of the truck really makes a difference. In my 17 years owning the rams only repairs made was one wheel speed sensor, that's all. No problems just really kept up with all the maintainance and used PUP synthetic oil. Total of over 220,000 trouble free miles and I tow a boat and camper. Best trucks ever and I have had Ford and Chevy trucks too.
Snoopy
NE Ga
Good grief with the tires and wheels you vacc are running what do you expect???
Zoe Saldana
california
6.4l
Did you adjust the gauges for the larger tires?
2018 2wd
The more and more I see what MPGs some of you guys are getting with stock trucks the more I smile lol .... I get close to 15 in town quite often which is probably 14 in reality and close to 20 on highway with the 37's on some 20x12s with 4.88s muahahaha !!!
Wes Veness
Winnipeg, Manitoba, Canada
2019 SLT Classic
Right!!! Mine didn't move when I put my lift on and added 35".... Makes you really wonder hoe some of them are driving their truck cuz I don't baby mine and my fuel consumption it pretty good considering what others are getting.
jib88fer
Hiding in the Hills, TN
Just sayin', I went from 66# 305/55 Falken Wildpeaks to 39# 275/60 Michelins and gained an instant 2mpg. Now the Falkens are for sale, at least until gas his $1 gallon again....
Black1500Ram
Scottsdale, AZ
Are you 2wd? Just curious how you’d get 4.88 in the front if you’re 4wd
You can't put 4.88's in even the earlier AAM (corporate) 1500's front diff,and yes he's 2wd.Don't get him started ;). I think Dilligaff will have alot to say,if this carries on :waytogo: :Big Laugh: This has been already argued to death ,hopefully it doesn't start all over again.The only way to put 4.88's under the front end of a 1500,is to swap to the earlier 2500's solid front axle,and lose the 1500's IFS diff
Black1500Ram
Scottsdale, AZ
Haha ok ok 2wd got it
UnleashedBeast
Pensacola, Fl.
Are both of you hand calculating MPG or relying on the lying dash readout for MPG?
I use the fuelly app on iPhone to calculate every fill up.
