not_that_ICE
- Jul 25, 2025
- 5
- 4
- Location
- Rexburg, Idaho, United States
- 2013
- 4.7L V8
I'm working on this 2013 ram 1500 with the 4.7 V8. After a ton of work fixing cylinder compression I went to start it and after a second of cranking it ran. In about a half a second I thought "good enough for me" shut it off so I could check out some stuff and went to turn it back on. I found out then that it was hard to start and it thumped around a lot. I got p0335 p0208 U110E and a fuel pressure circuit code that hasn't reappeared. I checked out the p0335 for the ckp circuit being open and I couldn't find anything wrong with the harness. I also know the battery is at a good voltage above 12v consistently but not quite 12.6v cuz charging and whatnot. I haven't looked into anything else just scratching my head. I know it could be the PCM but every time I think it's a computer I dig more and find some obvious issues. Could there be anything I could check before I look at new computers?
EDIT: I'm not ready to blame the sensors either because there are so many opens according to the DTC but I could replace those and see what that gets me
