Need Help - P018C
VdubBry
Hey all,
2013 Hemi, Check engine light is on, not clearable, used a basic OBD scanner and I have P018C.
I checked the Tech Info forum and couldn't find P018C but online found it means:
DTC Description: Fuel Pressure (Sensor B) Circuit Low
Sensor B
End of Range - Circuit Lower Than Expected
Trying to look on the mopar parts site and I don't see what sensor I should be ordering or trying to troubleshoot.
Any ideas? Thank you!
HemiRoar
Toronto
5.7L Hemi V8
a 2013 should still be under warranty..unless you're past the mileage. I'd take it in and let them fix it.
VdubBry
VdubBry
Thanks, I wish I was, she is way past on the mileage. Coming up on 50K.
HemiRoar
Toronto
5.7L Hemi V8
oh man, sorry!
another option would be, call the parts department and advise them about the code...let them do the research and call you back with the part #..
VdubBry
VdubBry
Thanks, didn't think about that. May give them a call and hope theyre not lazy lol
Tach_tech
5.7L HEMI
Causes of that DTC are.
Fuel rail pressure sensor
PCM
wiring
Nightwing1
TX
5.7 Liter HEMI
Hey guys just wanted to add to this thread. I too got this code. It isn't affecting the drive-ability to the truck for me.
I can't get into the dealership today but I was curious if there were any long term effects I have to worry about if I keep driving it until I get it fixed? Other than the obvious not reading the fuel pressure correctly?
It's still under warranty. I got the extended warranty for it when I bought it used so I am covered there. I could fix it myself but why if I got it covered?
Thanks guys.
Retlow8
Red Bud, IL
Any news of what the problem was? My 13 has the same code being thrown up. 45xxx miles I wouldn't expect this to be happening.
Did you get this resolved?
Was it covered under the power train warranty?
BrianandChrissy
Buffalo NY
2016 big horn crew cab
5.7 hemi, vararam CAI
Dont u all have 5 year 60,000 mile powertrain warrantee?
Sent from my SM-G935V using Tapatalk
