Need help with coil springs
Miken1213
I have a Dodge Ram 1500 1996 5.9 I took off my front wheel to replace the shocks on the front and after I did that I noticed that I was able to pull out the coil spring without a spring compressor is this normal since I took the shock out I also measured it its 16 inches long are the springs no good should I replace them or is this normal thanks
mrbfy
360V8 5.9L
When you remove the lower shock mount and jack up the front of truck it will relieve pressure on the coils and allow for you to pull them out. The sway bar will make this not as simple but unbolt that and the springs come right out.
Happened to me. I'm thinking they were shot , but with coil springs it all works that way.
Depends on how long the lines are when you Jack it up .
Reticle918
