Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have a 2000 Ram and the high beam and the low beam lights are on all the time. I have replaced the head light switch, dimmer switch and the relay is good. What else could be the problem?
wiring maybe. Need to trace out all the wiring since its an old truck and could be that simple. Are you sure its both high and low? you can see both filaments lit?
You have the 2000 sport headlights, four bulb type. It might be the DRl (daytime running lights) module if you have one. A small black box on the drivers inner fender between the power distribution box and the firewall.
